I want to use an old DAQCard-AI-16E-4 with Labview 9.0 / 2009
I use LabView 9.0 / 2009 and wonna utilize an old DAQCard-AI-16E-4, but I can't select the corresponding Card in LabView.
Is there a possibility to use that card under Labview 9.0 /2009?
(3,208 Views)
Did you install the correct driver? What functions are you trying to use? You cannot use the DAQ Assistant or the DAQmx functions. You must use the traditional DAQ functions.
(3,203 Views)
Thanks for the quick answer! I haven't installed any driver yet.
Once I have inserted the card, there was a driver installed automatically.
I will try to use the traditional functions now.
(3,196 Views)
