I want to use two analog channels and one digital simultaneously
Hello and thanks in advance for reading this!
What I am trying to do is generate two different signals from the output channels of my interface card (PCI6024E) and simultaneously use a digital line so that I can switch two tranzistors (one NPN, one PNP) which actually control the "flow" of the two signals. This means that both signals need to be "active" while the VI is running and at the same time whenever I want to choose the signal not in use I need to use the digital line so that I switch the tranzistors and I get the desired signal.
I have already created a VI which activates a digital line and while I was trying to add with the NI-DAQmx Assistant the first digital output, I discovered that it c
ould not be used simultaneously, because there was the error code -200324 saying that "Device not available in NI-DAQmx. It is possible that the device is being used by Traditional NI-DAQ or that the device is being reset."
I did reset the device but as I get it when VI runs, it cannot have an active digital channel and an analog output channel at the same time (not to mention two analog channels). Correct me (And make my day:) if I am wrong but this seems to be the case. Thanks a lot for your time!
Message 1 of 1
(2,449 Views)
