I would be grateful if to could help me build a VI to allow calibration of a load cell
Part one project objectives are to research the hardware and software required to enable the Bee Hive Weighing application and electronic circuit to be completed in semester 6
The six key objectives follow         Monitor and trend weight gain / loss         Raise alarms from rapid increases or decreases in weight         Calculate moisture content of nectar         Monitor and trend temperature inside hive         Monitor and trend humidity inside hive         Early detection of disease in the hiveIn order to meet the objectives set out above the following data will be required.
  • Hive weight
  • Hive temperature.
  • Hive humidity.
  • Capture reading at 0700 and 20hrs.
At present I am having difficulty with a calibration routine for the load cell can you help?
(2,769 Views)
You can try to convert the dynamic data type to an array.  Go do Express -> Signal Manip -> DDT to.
Kudos and Accepted as Solution are welcome!
(2,743 Views)
