ISA DAQ (AT-MIO-16X) in LabView7.x under 2k or XP
HI,
I'm looking for someone with eperience in using an (old) AT-MIO-16X (ISA) DAQ-Card with WINXP. I found such an old card and got it running with NIDAQ 6,1 under WINNT4.0. Unfortunately there is no support for such ISA devices under XP or 2k with a higher NI-DAQ driver.
I would like to know if I could use (configure and measure - AnalogIN and AnalogOUT) this device over an RDA-Server remotely in an up-to-date LabView 7.x? Hope there is somebody how could give me some information.
Thanks.
christian511
(2,798 Views)
Sorry but there is no way to use this board with a modern operating system. The best advice I can give you is to contact your local NI branch and ask for a hardware upgrade. Boards like the M-Series or USB-DAQ products are low-cost, faster and much more accurate than the AT-MIO-16X and if you do a hardware upgrade you will even get a discount.
Jochen Klier
National Instruments Germany
(2,792 Views)
