Identifying Vision Acquistion Cables
I have a new problem here and it has to do with NI cables for the 100 pin connector on the framegrabbers. A box of suspect cables was dropped on my desk to ascertain their serviceability. I have a cable with two mating plugs and cable with three mating plug. I even has a cable that says it's a 14-bit cable. I need some help. Here are some part numbers:
1847743A-02   Described as type D100100 2605 Flex with two mating plugs
1847434A-02   Described as type D100100 3406 Flex with three mating plugs
I have done a search of your website for these cables with negative results. I might have to purchase new cables depending on the outcome.
(3,090 Views)
Your cables are designed to be used with the SCB-100 connector block.  They are pretty old cables.  Below is a link to three pages that describe the use of the D100100 cables.
D100100 Search results:
http://search.ni.com/nisearch/app/main?q=d100100&x=0&y=0
Nick Keel
Product Manager - NI VeriStand and Model Interface Toolkit
(3,069 Views)
