If i sample multiple Differential channels, do i need multiple individual bias-resistors?
See attached PDF.
Trying to measure 3 pairs of a synchro..floating.  When I measure diff S1>S2 (AI0 rel to AI8) I have a biased resistor ( r3 and r2 to AIGND ).  Now I want to measure differentially S2>S3 ( AI1 rel to AI9).  Is my setup regarding the biasing resistors legit?  Can you "short" to analog channels together , AI0 and Ai10, AI1 and AI8 , AI2 and AI9 to get the 3 pairs of differential measurements I want??  Should the biasing resistors be as close to the DAQ as possible or doesn't it matter?
Thanks..
Message 1 of 11
(4,345 Views)
S1, S2, and S3 should each have a biased resistor.
It might be easier to just use 3 referenced single ended channels to measure your S1, S2, and S3.  You can then do whatever math is needed in the software.
Message 2 of 11
(4,321 Views)
 They do as shown in the (earlier) attached drawing.
Don't understand this one.  I need to measure ..say..S1 relative to S2.  If I tie S1 to an analog in channel and reference S2 to an analog ground...How would I later be able to measure ..say..S2>S3 ??  S2 is tied to ground to get the RSE configuration.
Message 3 of 11
(4,312 Views)
You don't tie S2 to GND.  You wire S1 to AI0, S2 to AI1, and S3 to AI2.  With the bias resistor, they should all have a voltage relative to GND.  So the idea is to measure S1, S2, and S3.  Then in software you can do S1-S2, S2-S3, S1-S3, etc. to get your differential measurements.
Message 4 of 11
(4,303 Views)
So the configuration and setup would be a "hybrid" from the document attached to obtain the required measurement you just described?? Analog In1 would be tied to S1 with a biased resistor tied to Analog In gnd.  Analog In2 would be tied to S2 also w a biased resistor tied to analog in gnd and the same for S3??  In my DAQ configuration in SW I would set the configuration to "RSE" for each channel I wish to measure then do as you say and take the difference??  ie S1 minus S2; S2 minus S3 etc??
thxs..
Message 5 of 11
(4,290 Views)
That is correct. You would set the configuration to "RSE" and do the differential math in software, as crossrulz stated.
Message 6 of 11
(4,267 Views)
So I'm a big visual guy and drew up this simplified drawing ( included) based on everyone's comments.  I want to make sure I understand this concept because it is far different than what I had read on and understood.  If someone would be so kind as to comment on my statements.  I don't understand cruz's comments if this dwg is correct.  From the sketch on the bottom left I measure AI1 (relative to AIGND) which electrically is the voltage across R1...also across S1/S2/R2 combination...figure to far right.   If I now measure the voltage at AI2 (relative to AIGND) its the voltage across R2..electrically the same as S2/S1/R1 combo.  This is the same potential as at AI1 isn't it??  What am I missing?
Thanks..
Message 7 of 11
(4,258 Views)
Sorry..crossrulz comments not cruz.
Message 8 of 11
(4,255 Views)
Have you tried wiring one end of s1 to ai1 and the other end to a bias resistor that goes to ai gnd? Same for s2, s3, etc
Message 9 of 11
(4,243 Views)
yes.  I just want to make sure what I'm doing is correct before I build/wire a test station.  Maybe I'm seeing what I want to not what I should.  That's why I asked the questions.
Message 10 of 11
(4,235 Views)
