In which pin(number) need to add thermocouple on DAQ CB-68LP ?
I want to read temperature whith thermocouple in LabVIEW. I don't know in which pin I need to add thermocouple on CB-68LP. Can you help?
(3,177 Views)
Since the CB-68 is just a dumb terminal block, it is impossible to say where you have to make the connections. It all depends on the actual DAQ device you are using and what channels you want to use on that. Select the channels and find the pin numbers. The CB-68 is numbered the same.
(3,165 Views)
Thank You for Your reply. Could you tell me, please, should I connect thermocuple excatly to the  CB-68 or should I use relays to connect thermocuple to them and then relays to  CB-68?
(3,153 Views)
Connect it directly. Why would you want to use a relay?
(3,142 Views)
