Incorrect Analog inputs PCI6052E-SCB68
Hi :
I have PCI6052E with the SCB68 Screw terminal.  I am trying to monitor an analog input from a sensor (the output has a positive and negative), and I am using AI-Ch01 on the SCB68 (I have it connected to PINS 33 and PIN66).  However, I get bad readings, the readings fluctuate from what the sensor outputs (around 5.12 V) to 0.00 Volts-10.00 Volts.  What am I doing incorrectly?
Mizar.
(3,999 Views)
Have you configured CH1 for differntial operation? That is how you have wired it up for , I believe, by using pins 33 (CH1) and 66 (CH9).
(3,987 Views)
Yes, that is how I have wired it.
Mizar.
(3,982 Views)
But have you configured that channel for differential mode in software- either via MAX or directly in your LabVIEW code?
(3,979 Views)
In addition to AK2DM's queries, one more query to you!
what is the sensor that are you using??
Message Edited by devchander on 11-05-2006 10:36 PM
(3,969 Views)
Hi:
Yes, I have the channel set to Differential mode in the measurement explorer.  Do I have to also set it in the same mode in LabView?.  I am using LabView 6.1.
The Sensor is a capacitive sensor with an analog output ranging from 0-10 Volts.  Based on the current measurement, the output should range anywhere from 4 Volts to 6 Volts DC.
--Mizar--
(3,957 Views)
