I have a problem regarding the connection diagram that SignalExpress is trying to use when looking at my DAQ.  I have a DAQ USB6009 connected to SignalExpress 2.5.  Originally, everything worked fine when I was running with the trial version of SignalExpress 2.5.  I have now upgraded to the full version and ever since, my readings from the DAQ are not correct.  After much searching, I found that the problem was that the connection diagram SignalExpress is using for its task does not match the physical connections on the DAQ anymore.  Specifically, SignalExpress is trying to use ground pins for the signals (i.e. it's wanting to use pins 1 & 2 for signal A when pin 1 is a ground pin according to the USB6009 manual...the manual says it should use pins 2&3, etc.)
Is it possible that a configuration file or similar was changed somehow upon installing the full version?  How do I go about changing the connection diagram in SignalExpress?
Thanks in advance for everybody's time.
-Ryan
