Incorrect task executing on SCB-68
I use SCB-68 device to generate clock signal. For that I use DAQ Assistant in my program. I need to generate sequence of pulse trains. For example 1000 pulses, delay 1 s, 2000 pulses, delay 1 s, 3000 pulses, delay 1 s and so on (see attachment). But when I start programm I see, that device genetates incorrect sequence of pulse trains: 1000 pulses, delay 1 s, 1000 pulses, delay 1 s, 1000 pulses, delay 1 s and so on. In other words DAQ assistant use first number for generage next pulse trains, but in fact, my program gives to DAQ assistant correct numbers. It seems like internal buffer of device, which store number of samples, don't update.
How can I fix it? Maybe there is way to update device buffers manually (in my program) or something like this?
(3,358 Views)
Two things,
  1. SCB 68 is a connector block and not a DAQ card Smiley Wink so, which DAQ card are you using??
  2. Are you using a counter/Timer channel on your card for this pulse generation??
(3,356 Views)
>SCB 68 is a connector block and not a DAQ card so, which DAQ card are you using??
Sorry, PCI-MIO-16E-4 🙂
In DAQ assistant I use Counter output (ctr0 hardware output). Is it that information, what you want to know?
(3,350 Views)
Problem has been solved with the help of NI technical support.
NI support suggested me to eliminate "First Call" check in block diagram of DAQ assistant.
(3,343 Views)
