Incorrect voltage reading on USB-6229 DAQ
I am attempting to read an analog voltage using a USB-6229 DAQ.
I have a voltage at ~6.7V that I read with a DMM (nothing connected to the DAQ).
When I try to read that same signal through AI0 (or AI1) and AIGND I read a steady 10.6V using Measurement & Automation Explorer.
When I have this signal connected to AI0/AIGND and read the same signal using the DMM, the DMM reading jumps to ~13V.
I assume there is some sort of grounding issue here somewhere.  Can anyone help me diagnose this problem I'm seeing?
Thank you,
Seth
(3,184 Views)
Hi Seth,
What is the signal source that you are reading?  Is this a grounded signal source (like a power supply) or is this a floating source (like a battery)? How do you have your signal wired?  Are you reading single ended or differential in MAX? The document below is a good reference for signal connections (take a look at Table 1):
Field Wiring and Noise Considerations
Jim Schwartz
(3,158 Views)
