Increase buffer size in daqmx read
Hi
How can you increase the buffer size in a daqmx read application? I have a sample programme which gives an error 200279.
Mal
(3,859 Views)
Hi Malkoba
Increase input buffer is a vi in daqmx functions palette.
See attached your modified vi
Besides increase input buffer, look at remaining data to be read. If reading is not quick enough, think about a producer/consumer structure ( search this web about the subject).
Your vi runs fine in my pc ( 1.7 Ghz, lv7.1, PCI6052E)
Greetings
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,844 Views)
