Increase external voltage from NI USB 6008
is it possible to increase the voltage coming from the pin 31?
I want to supply a relay which needs 5 - 12 V with the DAQ. But it doesn't work because it doesn't get quite to 5 Volts.
So I need more volts... the current of 200mA is plenty. The relay only needs 20mA
So can i just use a voltage converter or is there another way?
Is it possible to connect the 2.5 V pinout to the 5 V and get 7.5 V?
Greetings and thanks for helping 🙂
(2,207 Views)
Accepted by topic author bobikobi
If your relay (datasheet?) works with 5V and draw only 20mA you should be able to drive it with the 5V+ (pin31) ... will it work when you connect it directly
BEWARE Do this always together with a 'free wheeling diode! to protect the 6008 5V from back EMF when disconnecting an inductor (relay coil))
However I assume you want to control the relay using a DO pin... and 'loose' some voltage .. a proper selected transistor can help.
No.
but you can use an external voltage supply .. (another 5V from another USB or ...)
But from your questions I have the impression, that you are not quite familar with electronics, so my advice would be to make a plan of what you want to connect how  and discuss it here or with some else BEFORE atually connecting it.
Greetings from Germany
Henrik
LV since v3.1
(2,158 Views)
