Increase overvoltage protection of a PCI-6133 + BNC-2110
Hello everyone, according to the data sheet the PCI-6133 has an overvoltage protection of 36V. I use this card in combination with a BNC-2110 connector block. Is there a simple way to increase the overvoltage protection of the analog inputs to 100V? My measurement signal is max. 5V, but in case of an error 100V can be present for a short time and I want to reduce the risk of a defective data acquisition card.
Many thanks and many greetings
Michael
Translated with www.DeepL.com/Translator
(2,191 Views)
An easy way:
First limit the input current by adding a resisitor 10k or 100k (BTW what is ýour source impedance?)
after the resistor add a limiting device: A 1N4148  to 5V.
this will limit only to positive 100V .. and depending on your needed bandwidth .. you build a RC lowpass, R your resistor and C in the diode.
or look for a TVS diode
but keep in mind that they have a leakage current!
A good source for circuit solutions : look at the schematics of DMM..
Greetings from Germany
Henrik
LV since v3.1
(2,174 Views)
