Increasing NI USB-6008 output voltage
Using the NI-USB 6008 device I am trying to measure and store the pressure data from a tire. The problem is that the omega make pressure sensor requires 10-15 volts DC excitation but the maximum that can be supplied from the USB 6008 device is 5 Volts. I am not sure what to do.
I tried it with the 5 volts supply from the device but I am not getting the correct readings.
(4,556 Views)
....external power supply? You can pick up a wall-wart for a couple of bucks, if you don't have one laying around already. 12v is the most common/cheapest in that range.
And yeah, I doubt you'd get the right readings with 5v either.
(4,555 Views)
So, the excitation and the ground will be connected to the 12 Volt power source and the output will connect to the analog input channel?
(4,554 Views)
keep in mind that the DAQ input can only handle +-10V.  So you may have to use a divider and/or use a buffer circuit.
(4,551 Views)
The external supply worked. The output voltage in b/w 1.3 and 3.7 volts so that is also with in limits. The signal is being read in the VI. The issue now is that, I get an error 'Error -200279' in between when the VI is running (showing correct readings). I believe this is due to the timing settings I have for this task in the measurement and automation explorer. I have selected
  • continuous samples
  • samples to read 1k
  • rate(Hz) 1k
Also in the block diagram the constant input to the wait until next ms multiple is 100.
Thanks for all the help!
(4,512 Views)
I think this link can be useful...
http://digital.ni.com/public.nsf/allkb/AB7D4CA85967804586257380006F0E62
(4,506 Views)
Got it to work. No error . Calibrated the transducer and it works fine.
Thanks everybody!
(4,426 Views)
