Independent control of channels on NI9269 card
I'm using a compacDAQ with a NI9269 AO card (4 channels).  Is it possible to have all four channels outputting different voltages at the same time?  Thank you.
(3,266 Views)
Hi  petedon
The NI9269 has a digital to analog converter for every channel. You will be able to output different voltages at the same time.
Jason L
Product Support Engineer
(3,259 Views)
Can I use this NI9269 AO card for measuring the analog voltage from sensor i.e. Can I use this card as a Analog Inpun card ??????
(3,186 Views)
No. As the specs clearly state, it is only an analog output module.
(3,177 Views)
