Initializing Controls on front panel
On my front panel, I have several controls that the user needs to set prior to running the program. The user will mostly enter in the same values each time on the front panel prior to running the program.  Is there a way to save these values in the control on the front panel, so that the user sees them each time when opening the .vi program file?
Marie
(3,491 Views)
Accepted by topic author Tupaj
Set the values that you want to be default then select the controls for which you want to hold the values then go to Edit and select Make Current Values default.
(3,485 Views)
