Installing DAQmx base driver on windows CE without active sync
Sir,
       I have to install a DAQmx base driver on windows CE for my DAQ application to run in windows CE. The normal method requires use of active sync which is not supported with the windows CE machine(x86 machine) i have.
Can u mention any alternate method of installing the "x86 windows CE driver" on my windows CE machine without using Active sync.
Thanks.
(3,810 Views)
Hi Bharath,
Would you tell me more about what kind of machine you're trying to use? I can only infer that you have a 32-bit Intel processor on a system running Windows CE, but what make and model is the computer? And what version of Windows CE is installed?
If your hardware and OS are supported [1], then it is possible to install DAQmx Base without using Active Sync, but you'll have to do it manually. You will need a way to copy files from your development machine to the Windows CE system. The files you need to copy are provided by the LabVIEW Mobile Module, so unless you have it, you won't be able to use DAQmx Base with your Windows CE system.
There are three files you need to copy, and they are located in C:\Program Files\National Instruments\NI-DAQmx Base\Pocket PC under two folders called damxbase_tpc2012 and visa_tpc2012 [2]. Copy the .cab files from those two folders to your Windows CE system and double click them to install. The only requirement on installation order is that you must install the VISA cab file before the DAQmx Base cab files.
[1] DAQmx Base Readme
http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmxbase/3.2/Windows%20Mobile-CE-XP-Vista/rea...
[2] Windows Explorer Screenshot
Message Edited by Joe F. on 04-17-2009 11:01 AM
Joe Friedchicken
NI Configuration Based Software
Get with your fellow OS users
[ Linux ]
Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
(3,753 Views)
