Instrument I/O error
We are trying to use the Instrument I/O assistant in Labview and are receiving an error that it is not installed correctly. We have installed the 488.2 and VISA, and then uninstalled and reinstalled the Instrument I/O assistant. We are still receiving the error.
(3,039 Views)
Hi Agata,
I was wondering if you've attempted everything mentioned in the discussion forum below.
http://forums.ni.com/ni/board/message?board.id=170&message.id=456705&requireLogin=False
Also, what versions of NI-VISA, NI-488.2 and LabVIEW do you have installed? Do the VISA paletted show up in your LabVIEW environment?
Raj
(3,019 Views)
