Integrate a CDAQ-9172 with a CRIO-9014
I have a cDAQ-9172 with 8 9211 modules and i want to integrate that with a cRIO-9014 with 2 9853 modules and 6 9211 modules. There is a way to do that in a stand alone system? Because I want to create a standalone measurement systems for trucks.
(2,975 Views)
Accepted by topic author MarcusBianchi
The cDAQ-9172 will need to be attached to a Windows PC (this doesn't necessarily need to be a desktop; something like an industrial controller or a laptop would also work) running DAQmx. The cDAQ-9172 cannot run 'standalone' like the cRIO-9014 can.
You cannot use the USB port on the cRIO-9014 to acquire from a CompactDAQ device.
(2,965 Views)
