Interfacing DAQ with connecor assembly SCXI 1349 : Shielded cable connector choice
I want to upgrade my system and placed order as per attachment.My requirement is to purchase following but with interfacing compatibility 1-NI PCI 6251 (part # 779070-01) 2-SCXI 1349 connector (part # 182671-01)(Already I have SCXI chassis 1000,Cards & terminal block) 3-Shielded DAQ cable ......???? To connect 1 and 2,I need 3 i.e.shielded cable but problem is I am unable to find the exact part number that matches pin Connector of 1 and 2.As SCXI 1349 have 68 pin female connector but What about 1 with above part #. a-Suggest pin connector of NI PCI 6251,a supporting diagram of connector would be a plus. b-Tell me exact cable name and part # for interfacing 1 and 2. c-My preference is shielded cable 2m in length.Screen shot of both ends of cable or exact link would be really appreciated. Your expedited response will assist me in ordering. Regards Waqas
(4,018 Views)
Hi waqas 10N,
The cable you need is the NI SHC68-68-EPM. The 2 meter length is part number 192061-02.
The product page for the cable is here.
(3,995 Views)
