Iotech Daqbook 260 trigger channel identification
Iotech Daqbook 260 with Labview 7.0 using latest iotech drivers and labview vi's. I'm using a trigger setup similar to the "Daq device main unit advanced analog input example". Data aquires if I use an immediate trigger but as soon as I choose a hardware trigger it comes up with error code 137 (daqAdvArm: Invalid Trigger channel) with all channels 0 to 48. With the immediate trigger, data gets stored in the array output with the first column being the first selected channel. I'm using a dbk45 in the first channel of the daqbook, followed by 2 dbk80's.
Thanks for your time and help, any other info needed please let me know.
(2,844 Views)
You should contact Iotech on this error because I am assuming they are the ones that developed these drivers to interface with LabVIEW. There is no way for us to diagnose this problem because we did not develop their drivers. You could always switch to our hardware which was developed to work seamlessly with LabVIEW. Have a Great Day!
George
(2,839 Views)
