Is BNC-2110 compatible with R-series devices?
I have a 7833R RIO DAQ card. Is it possible to interface its connector 0 to a BNC-2110 adapter?
(3,082 Views)
Hey setu_mohta,
The connector block that we reccommend to use with the 7833R is the SCB-68. However, if you have a BNC-2110 laying around I would give it a try. While the BNC-2110 is not fully compatible with our R Series cards, the 68-pin connector is the same and I would think that the analog lines would work. If you are just now setting up a system and looking to get the right hardware I would get the SCB-68 rather than the BNC-2110.
Doug B
(3,068 Views)
