Is NI-DAQ 6.9.3 compatible with Labview 7.0
I have an old lab-pc+ daq board that I want to use. So I downloaded ni-daq 6.9.3 driver because ni-daq 7.0 does not support the lab-pc+. I had previously downloaded labview 7.0. I was wondering whether I have to download labview 6.1 instead to be compatible with ni-daq 6.9.3 ( as it came with an additional file to make it run on Labview 6.1) or whether Labview 7.0 will be ok.
(2,666 Views)
Alesya,
You can use NI-DAQ 6.9.3 with LabVIEW 7.0. You will need to download the NI-DAQ 6.9.3 support for LabVIEW 6.1. During the installation of NI-DAQ 6.9.3, you should include support for LabVIEW 6.1 and change the installation location of this support to the LabVIEW 7.0 folder on your computer. If you follow this procedure, you should be able to use your Lab-PC+ with LabVIEW 7.0.
Good luck with your application.
Spencer S.
(2,666 Views)
