Is NI-DAQmx 7.3 compatible with XEON processor ?
I tried to install NI-DAQmx 7.3 on my PC with a XEON 3 GHz processor. After reboot, Windows XP does not start properly. So I suspect DAQmx 7.3 being NOT compatible with XEON processor.
Has someone the same problem ? Which solution ?
(3,483 Views)
I am using NI-DAQ 7.3.1 and a dual Xeon processor machine and haven't had any problems. I haven't heard of any compatibility problems.
Randall Pursley
(3,465 Views)
NI-DAQmx 7.3 is definitely compatible with XEON processors. What exact errors are you getting?
(3,426 Views)
Hello All,
The driver NI-DAQ 7.3 is compatible with Xeon processor 32 bit versions. But for now, no testing has been done on the specific system with the version EM64T of Xeon processor. I think that this is the source of your problem.
As a result, there may be incompatibilities between this new processor and our existing drivers.
The NI R&D works on this subject.
Best Regards,
Sanaa TAZI
National Instruments France
Sanaa T.
(3,401 Views)
