Is NI USB-5133 compatible with the CompactRIO platform?
Hi everyone,
I would like to replace a PC-based setup with CompactRIO hardware. I'm not looking at PXI systems because they are too expensive.
However, there is no CompactRIO digitizer fast enough for my application (60MS/s, 8 bit resolution, +/- 10V),
the fastest one available seems to be the NI 9775, only 20MS/s. The same at 60MS/s would have been great...
So, it happens that the NI USB-5133 could do the trick (the trigger would be sent by one of the module of the compactRIO). The question is: is it compatible? Can I connect it to the compactRIO and get the data?
Alexis
(2,312 Views)
Hi Alexis85v,
If I understand correctly, you want to plug the USB-5133 on a cRIO's USB port. It's not possible.
Feel free to contact the sales department to discuss about the hardware solution.
Eloise
NI France
(2,276 Views)
