Is XPUSB Hotfix required?
I have just installed the drivers and software which came with the USB-6008 on a Windows XP PC.  The MAX software is giving me a message which says a hotfix (WindowsXPUSBHotfix) is required.  The link leads to a Microsoft site which says do not install the fix unless data corruption is occuring.  Should I therefore install the fix anyway or try the unit to see if data problems occur?
(5,604 Views)
How are you going to know when the data's getting corrupted?  Good-enough error handling in your code for that situation?
Personally I'd install it anyways.  I downloaded the 940f1 DAQmx installer, and the hot fix, then burned them both to a DVD.  Put the disc in, run the DAQmx installer, then run the hotfix and be done with it.
Is it required to work?  Not really.  Recommended?  I say yes.
(5,599 Views)
