Is is a proper way to solve the problem of high common-mode voltage?
Would you mind to help me download it and transfer it to me? I can't open it or open a blank page (from google search)...
Thank you.
Message 21 of 30
(1,741 Views)
here we go
Greetings from Germany
Henrik
LV since v3.1
Message 22 of 30
(1,736 Views)
Got it! Thank you!
Message 23 of 30
(1,731 Views)
Before spending time and money in building your own system:
Use a industrial isolation amplifier:
Here a source directly made for shunt measurements (sorry, in german, buy just call them 🙂 )
http://www.relmatic.ch/an/signalwandler-trennverst%C3%A4rker/im-industriegeh%C3%A4use-multispannungs...
Or (ab)use a isolation bridge amplifier  like this one:
With two additional resistors you can use it for shunt measurement. Or again ask them if they have something for shunts.
Henrik
LV since v3.1
Message 24 of 30
(1,724 Views)
I am confused.  In the other thread you indicated that your switching frequency was 30-40 kHz.  Now you are talking about 350 us rise time which implies a much lower frequency.
I put together a simple program to show the effect of reduced bandwidth on measurement accuracy.  I generated a square wave. I ran it through a first order Butterworth low pass filter with the cutoff frequency set to twice the signal frequency.  This filter is a good representation of the behavior of the amplifier with the same bandwidth. I measure the RMS value of the original signal and the filtered signal. For the values indicated above the error is 17%.  To get the error below 0.5% the filter (amplifier) bandwidth needs to be >35.2 times the signal frequency. If the waveform is more complex than a square wave, such as having narrow spikes, the bandwidth requirement will probably be greater.
Your 2 kHz bandwidth system can measure with <0.5% accuracy square waves up to 56.8 Hz.
Also, the datasheet for the IMC-A-R0001 gives no indication that it has any isolation or that it can handle any common mode voltages. With a sampling rate of 900 samples/second it will not give meaningful results for square waves above a few tens of hertz.
Lynn
Message 25 of 30
(1,712 Views)
Sincerly appreciate for your help though I can't understand the German and the page of  isolation bridge amplifier can't be open. Sigh~
Message 26 of 30
(1,705 Views)
The control principle is complex. In a word the switches turnr on/off so frequently that the output current can precisely follow the instruction. So even during the rise/fall, the  switches are turning on/off frequenty.
Message 27 of 30
(1,703 Views)
Well, finding the contact (Kontakt) page with a phone number shouldn't be too hard 😉
And like all small countries, their population is usually able to speak multiple languages ..
Spoiler
frankly, I have never met any swiss who wasn't able to speak (at least) german, french and english
and the second link plus comments include enough key word for any search engine 😛
Henrik
LV since v3.1
Message 28 of 30
(1,694 Views)
Just came across this IA for current shunt monitoring with +-250V input range
http://cds.linear.com/docs/en/datasheet/1990fb.pdf
However the layout with HV input pins next to -V and V_ref  in S8 package leaves <0.8mm isolation ....
Henrik
LV since v3.1
Message 29 of 30
(1,654 Views)
Hi, Henrik~
Thank you for your efforts sincerely!
Now I prefer to float the reference "ground" of IA because the available IA's CMRR is not high enough especially in high frequency. For example, the common-mode voltage is 160V and the  differencial signal is 50mV. If CMRR is 80dB, the common-mode noise will be 16mV resulting the error of 32%!!!
Best Regards.
xcuresme
Message 30 of 30
(1,650 Views)
