07-16-2009 10:59 AM
I have an application where I would like to synchronize three DAQ cards using their RTSI capability. However, for development purposes, I would like to monitor the clock lines of the RTSI bus using an oscilloscope. Is it okay to use a four-connector RTSI cable with my three DAQ card setup and leave one connector free for probing, or will the unterminated connector cause problems with the RTSI bus?
Chris James
07-17-2009 03:33 PM
Hi Chris,
Thank you for posting to the NI Forums! There will be no problem leaving the fourth connector unconnected. This is the same as leaving a slot empty in a PXI chassis. There is no issue here. Have a great weekend!
