Is it possible to loop AI Voltage readings without creating a new task everytime?
I would like to repeatedly make n Analog readings in a program, however, I am unable to accomplish this without creating a new task each time... perhaps I'm doing something wrong.
Here is my pseudo-code:
DAQmxErrChk(DAQmxCreateTask("", &taskHandleAI));
DAQmxErrChk(DAQmxCreateAIVoltageChan(taskHandleAI, ...));
DAQmxErrChk(DAQmxCfgSampClkTiming(taskHandleAI,...));
Loop start
DAQmxErrChk(DAQmxStartTask(*taskHandleAI));
DAQmxErrChk(DAQmxWaitUntilTaskDone(*taskHandleAI, 0.001));
DAQmxErrChk(DAQmxReadAnalogF64(*taskHandleAI, ...));
DAQmxErrChk(DAQmxStopTask(*taskHandleAI));
parse_data_and_do_something();
Loop end
The very first read seems to work fine, however, all subsequent reads gets the following error message:
DAQmx Error: Measurements: Task specified is invalid or does not exist.
Status Code: -200088
Does anyone have a clue what is happening?
(3,324 Views)
Without actually seeing your block diagram it is hard to see what might be the problem. But from just looking at your pseudo-code I would move the StartTask, WaituntilTaskDone, and StopTask outside of the loop.  Just have the ReadTask inside the loop.
Hope this helps, Good-Luck.
Steven
(3,316 Views)
Sorry, I'm implementing this in C so I don't have block diagrams...
I tried moving start/wait/stop outside of the loop, the exact same error occurs.
I actually don't understand why you would do that though...
Let's say the loop only iterates 2 cycles, if we unroll the code I have, we get:
//first loop
//second loop
Your suggestion seems to imply the following:
//first loop
//secondloop
What triggers the read to start in this case?
(3,310 Views)
The DAQmxErrChk(DAQmxReadAnalogF64(*taskHandleAI, ...)); initiates a read. What did you think did?
Noticed the wait until task is done function. That does not belong anywhere. Have you looked at the C examples (i.e. Cont Acq-Int Clk)
(3,297 Views)
