Is it possible to maintain the last AO value after the DAQmx task is done on device DAQ USB-6341 ?
Hi all,
I use the device DAQ USB-6341 to generate the desired voltage waveform by the "finite samples" sample mode.
I notice that the channel resets to zero volts after the DAQmx task is done and the DAQ USB-6341 does not have
the property AO.idleOutputBehavior to select "Maintain Existing Value".
How can I maintain the last AO value after the DAQmx task is done on device DAQ USB-6341 ?
Thanks.
Godel
Message 1 of 1
(4,016 Views)
