Is the PCI-6220 compatable with windows 7 64 bit
dfdfbgdgdfggrergfergre
Message 1 of 9
(5,756 Views)
The drivers are 32-bit, but you can run it on a 64-bit machine.
Message 2 of 9
(5,753 Views)
What driver file do I use?  No luck with NI-DAQmx Device Driver 9.8
Message 3 of 9
(5,744 Views)
According to your other posts, it is recognized. Your tasks and scales are not. Big difference. Your tasks and scales could be referring to a different device. Perhaps you created them for dev2 and on the new pc it is dev1.
Message 4 of 9
(5,734 Views)
The tasks and scales were created during the import and reference the "Simulated" PCI-6220.  If I "Reset Configuration Data" to delete my import, I still see the "recognized" PCI-6220.  In addtion, I do not see the SCXI-1000 attached to the PCI-6220 or any sensors attached there to.  If I try to create a task, it get "No Ssupported devices found"
Message 5 of 9
(5,730 Views)
In addtion, no menu appears when the device is right clicked.
Message 6 of 9
(5,726 Views)
No options for the device
Message 7 of 9
(5,715 Views)
Was the device installed in the computer before DAQmx was installed?  If so, it may be best to:
1) Turn off PC to remove PCI card
2) Uninstall DAQmx (Programs and Features >> Add or Remove Programs >> National Instruments)
3) Restart computer, reinstall DAQmx
4) Turn off PC, install 6220 card
Message 8 of 9
(5,680 Views)
You will have to create the SCXI chassis in MAX to get it to appear.  From here you will be able to create tasks.
start at step ten here: http://www.ni.com/pdf/manuals/373236m.pdf
J Newk
Systems Engineer
Message 9 of 9
(5,675 Views)
