Is the PCI-6259 card compatible with Asus P5Q?
Hi all,
I would like to know if there are any incompatibilities between the NI PCI-6285 and the ASUS P5Q motherboard (https://www.asus.com/it/Motherboards/P5Q/).
There is a list of DAQ cards with tested PC setups?
Thanks everyone,
Best regards.
Sergio
(2,468 Views)
Hi Sergi0,
there are no incompatibilities between the DAQ board and the ASUS motherboard. PCI DAQ board uses the PCI standard and if you have the proper low level driver installed, all should work properly.
(2,424 Views)
