04-13-2009 05:56 PM
Solved! Go to Solution.
04-14-2009 11:08 AM
Hi KMoller,
It sounds to me like you should be able to replace your group configuration setup with a DAQmx Create Virtual Channe.vi and then simply input your channels in the syntax according to this KB. Let me know what other specific questions you have- or if this isn't what you're looking for. Thanks!
04-14-2009 11:48 AM
Thanks for the suggestion, aNltaB. I did this when I did the original conversion to DAQmx. The problem I had was that for the Calibration Case all of the channels available on the 1102 modules were set up. Then, when the true test data acquisition portion was run, it used only the channels, in possibly a wierd order, that the user had selected.
I am going to split the 1102 channel setup into a Calibration Acq vi and a Test Data Acq vi & set the channels appropriately in each vi, making sure to close the specific task when leaving one or the other. I think this should work.
04-15-2009 10:37 AM
Hi Kmoller,
That sounds like a good idea, if it doesn't work, let me know. Have a good one!
04-15-2009 11:12 AM
