Is there a labview driver available for the NI PCI 6110?
I have a PCI 6110 card which I want to use to acquire two analog and one digital signal simulataneously at regular triggers. I have just started using LabVIEW so I was wondering if there is a LabVIEW driver which is already available.
Rahul
(3,033 Views)
Hi Rahul,
The PCI 6110 card uses the DAQmx drivers, of which the latest windows version can be found here.
These drivers are suitable for windows and LabVIEW 2009 or above. If you have any other system then please let me know and I will find you the appropriate drivers.
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(3,027 Views)
