Is there a way or a DAQ that can have Analog Output floating?
The fact that AO voltage are usually grounded make it troublesome to add two voltages.
Thank you very much!
Hongshi
(3,549 Views)
You can use an op-amp to add voltages.
http://www.electronics-tutorials.ws/opamp/opamp_4.html
(3,548 Views)
Hi hongshi,
The NI 9269 C Series module has channel-to-channel isolation and supports stacking channels for up to +/-40 V output. Is that what you are trying to do?
(The SCXI-1124 also supports this.)
Brad
Brad Keryan
NI R&D
(3,545 Views)
Well, I should definitely try that!
Thank you!
(3,528 Views)
Yeah, the isolated channel is what I want, but it's a little too expensive and not a DAQ.
Thank you anyway!
Hongshi
(3,527 Views)
