Is there a way to simulate a PCI-6014 card within DAQMX & and Measurement Studio ?
Our programmers would like to develop and modify code in DAQMX and Measurement Studio without having physical hardware (AD card, 2345 module carrier, and modules) attached.  I can simulate PCI-6221 and attached modulues, but I have not seen a simulation for the PCI-6014 card.  Does one exist or is there some other way?
(2,881 Views)
Thank you for posting to the NI Forums! There is no option to simulate the 6014; however, you can simulate a similar card and most likely your programming would not be affected. The PCI-6024E is a very similar card (12 bit resolution instead of 16) that you could use as a replacement for simulation purposes. Hope this helps! Let me know if you have any further questions.
Margaret Barrett
Digital Multimeters and LCR Meters
(2,864 Views)
