Is there an adapter for connecting an old SCXI-1000 to NB-MIO-16 board cable to a newer multifunction board?
The cable I have has a part number of 182323-10M (circa 1995).  It has a 50-pin female connector of some sort (original) on the NB-MIO side and a standard 68-pin connector on the SCXI side.
(3,469 Views)
Hey Larry,
What is the newer multifunction board that you are looking into?
Efrain G.
Visit http://www.ni.com/gettingstarted/ for step-by-step help in setting up your system.
(3,441 Views)
Hi Efrain,
I'm trying to consider options, so there's several, mostly low end multifunction boards.  For example:
PXIe-6361
PCI-62xx series
PXI-7841
Thanks.
Larry
(3,437 Views)
Hi Larry,
There is not such and adapter as far as I know, but you can just get a 68 pin cable to connect your controller board to the SCXI 1000. For example you can use one of our SHC 68-68 cables to connect your SCXI 1000 with any of our 62xx series boards.
Efrain G.
(3,420 Views)
