Is there any way to modify the sinewave 'output' of a simulated device?
I am working on a LV data collection and analysis VI in LabView that interfaces with a CDAQ 9178 chasis loaded with 9215 A/D modules.  Within the Measurement & Automation Explorer I have succesfully set up simulated devices that are working with my code and I am receiving the standard sinewave/5(?)% noise signal.
However, to really test my application I need a slightly different sinewave with a high frequency (1-10hz vs the <<1hz sent by the simulated device).  Is there anyway to modify or get the simulated device to output a different wave?  If not,  are there any other simple ways to simulate the device?  I could write another VI to send out a sinewave but was looking for a more obvious or simpler solution first.
(2,988 Views)
Accepted by topic author BJ37
No. What you would need to do is call one of the generate waveform functions instead of the DAQmx Read. Placing both inside a case or  statement or conditional disable structure is pretty simple.
(2,967 Views)
I put one together and it did go much easier than I expected.
(2,943 Views)
