Isdaq does not see my NI PCI-6221 restart
Hi everyone,
I'm running a NI-PCI-6221 DAq on a Mac G% using Mac OS 10.5.6. The system was running fine until I shut down. Now the card is not seen by Isdaq and the System PCI card info shows the card but indicates the driver is not installed. I reinstalled NI-DAQmx Base 3.2.0 but no better results. Any help?
(3,299 Views)
OK. I figured it out. I had hit the reset button after installing a GPIB board and that set all the dates on the library files to 1969 and the driver appeared not to be installed. After resetting the date/time and restarting I found the DAQ with Isdaq and all is fine.
(3,291 Views)
Hey Johnny,
Glad you were able to figure it out!  Have a great day.
-John Sullivan
Problem Solver
(3,274 Views)
