Issue with connecting NI-MAX and Crio-9025
When trying to setup a virtual channel through NI-MAX I'm running in to the issue where the chassis is listed under Remote Systems and thus I can not go though the DATA Neighbor to set up my channel. Does anyone know how to either set up a virtual channel in remote systems or how I can get the Crio to be listed under My System.
(2,970 Views)
Unlike DAQ devices, you can't set up a virtual channel in NI-MAX on a cRIO 9025 since it's a remote system. What exactly are you trying to accomplish with a virtual channel? Perhaps we can offer some insight as how to do it.
Francine P.
Applications Engineering
(2,913 Views)
The goal is to get an error estimate the way that is shown in the link below for our strain gauges. The main reason behind this is we are having an issue with our strain/stress readings fluctuating more then they did on a previous test.Our average delta was 100 psi on an old test and now we we are getting 200 psi. There are times when it peaks way beyond this average which I tend to dismiss since it is single data point which the previous and later points are within the average.
https://www.ni.com/getting-started/set-up-hardware/data-acquisition/strain-gages
(2,910 Views)
V-Channel Set Up
(2,908 Views)
You can use NI Distributed Systems Manager with your cRIO, which has similar functionality to an NI MAX Test Panel for DAQ. H
Alternatively, you can use scan mode in LabVIEW to view incoming data. Here's a page with an explanation of how scan mode works and a tutorial on how to use it:
Getting Started with CompactRIO - Performing Basic Control with Real-Time Scan Mode
Francine P.
(2,902 Views)
