LAN-Enabled DAQ
Hi All,
Is there any NI DAQ Products that LAN enabled? or LXI compatible.
I mean User can remote control the device and directly get the DATA via Ethernet.
thank you!! Smiley Happy
nonomiya
(3,849 Views)
Hi!
No, we have no LXI devices!Why donn't use LabVIEW with its Build-In Web Browser (Remote Monitoring/Controlling of VIs) or the new Measurement Studio 8.0.1 with its pallet of Web Publishing Tools?
Kind Regards, Christian
(3,846 Views)
The LabVIEW RT systems like PXI, cFP, and cRIO are all used and controlled via ethernet.  You may want to take a look at them.
-Josh
(3,833 Views)
One more thing.  NI does sell a PCI-1588 board that is capable of synchronizing a PCI system with PCI DAQ boards over ethernet to multiple systems and other 1588 enabled devices.
-Josh
(3,830 Views)
