LINUX error running lsdaq: line 7: 5652 Aborted
Hello all,
Running under SuSE 9.2 I first uninstalled the drivers for my NI 6220 card -it seemed that I had a conflict  with a new kernel-
then I install all again and now I can't find the card.
I obtained the ISO that I used for make it works before here:
http://digital.ni.com/softlib.nsf/websearch/468BBD82887888978625712C0070509A?opendocument&node=13206...
and I tried what is suggested in another thread here,
http://forums.ni.com/ni/board/message?board.id=250&message.id=21486&requireLogin=False
Everything's is going fine  following that procedure -apparently I'm not obtaining errors- but still I'm not reaching the card.
If you run /usr/local/natinst/nidaqmxbase/bin/lsdaq
this is the output:
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
.//lsdaq: line 7:  5652 Aborted                 /etc/natinst/nidaqmxbase/bin/daqmxbase_listdevices
Any idea of how can I proceed to have the card working again?
(It was working with the original kernel, 2.6.8-24-smp, but after "dowgrading" to this kernel again it's not working Smiley Sad)
Thanks to all in advance !
(3,082 Views)
please try that:
http://digital.ni.com/public.nsf/websearch/54240C0BA201DD068625711100571CC8?OpenDocument
I hope it will solve your problem.
(3,050 Views)
