LabVIEW programs to increase the framerate of a camera
I am using a Basler cameralink camera (A504K) with a card grabber PCIE 1429. The camera has a frame rate of 500fps with a resolution of 1280x1024.
I want to increase its frame rate beyond 500fps. So, is there any specific LabVIEW VI (program) to do so ,or it is required to configure in MAX. If so, then
how? Can anyone please help me out in this regard?
Thanks!
(2,993 Views)
1. Wrong forum, next time pleas post to the Machine Vision Forums.
2. With the maximum resultion you can not go faster then 500fps. You will have to decrease the resolution to go faster. But this is well documented in the cameras manual.
Christian
(2,972 Views)
