01-27-2016 04:43 AM
Hola,
Estoy probando la version de LabView 15, actualmente cuento con una tarjeta PCI 6024E instalada en una laptop y labview signal express pero quiero ver si es posible hacer una tarea mas especifica. El problema que tengo es que a pesar de haber instalado Labview 2015 y el DAQmx 2015.0 los cuales son compatibles con la tarjeta, al tratar de usar la tarjeta en LabView no aparece el toolkit de DAQ assitant. Lo he buscado en los toolkits adicionales de LabView y no lo pude localizar, no se si alguien sepa en donde pueda obtenerlo para poder hacer mi prueba.
Mil gracial,
Cinthya
01-27-2016
06:53 AM
- last edited on
09-18-2026
03:31 PM
by
Content Cleaner
There is no such thing as DAQmx 2015. The latest is 15.1.1 at https://www.ni.com/en/support/downloads/drivers/download.ni-daq-mx.html#288245
Make sure that is what you have installed. You can't install a pic device on a laptop so your comment about that does not make much sense.
01-27-2016 08:00 AM
You are right, I have the NI DAQCard 6024E installed on the laptop.
I have installed the DAQ1501 and actually I am looking for DAQ Assistant toolkit on labview, It looks like it is not included. I have looking for aditional Modules that contain this toolkit in order to use labview with my card but I haven't found any yet.
01-27-2016 08:11 AM
