Labview DAQ, error ''This resource is reserved''
i need some assistance regarding a NI 9219 DAQ module, controlled in Labview, basically i have 2 separate case structures and one DAQ assistant in each case. When i need to switch between them i get an error from DAQ ''this specified resource is reserved'', something like that. I have data aquisition from 3 different chanells simultaneously. How can i fix this?
Thanks in advance!!
(5,400 Views)
Why do you need to switch between them? You can't have two different tasks for the same hardware resource. Please explain your reasoning for two different tasks.
(5,394 Views)
I need to discharge a battery for x minutes, then stop for y minutes and so on until a condition is verified, and i used a state machine architecture, but now i solved the problem, the resource had to be stopped before switching. On the other hand which is the best solution to export data from DAQ, i am currently using Write to Meas File. I want to export all the data in the same file
Thanks!
(5,387 Views)
I prefer using the Logging function DAQmx to stream the data to a TDMS file.  Much more efficient than anything else you come up with.  But you will want a single task.  I advise to get away from using the DAQ Assistant and actually use the DAQmx API.  Things will become a lot easier on you for situations like this.  Instead of a new task, you should just be writing different data.
(5,380 Views)
I can not  find icon DAQ  Acquisition in LabView on table Function ->Input.Have we connect card DAQ with PC before started with Labview,haven't?.
(5,298 Views)
Maybe you should check the connection within MAX( measurememt automation explorer) and also look for DAQ in Functions-Express-DAQ mx
(5,290 Views)
