Labview NI-Daqmx can't locate my Daq board
Im using a MicroDaq USB 1208LS, and am attemtping to monitor a pressure sensitive resistor using the "continuous measurement and logging" premade .Vi in labview. However the program doesn't recognize / can't locate the daq, even though both instacal and tracer daq can. Any help?
(4,213 Views)
DAQmx is only for NI boards so your device is not supposed to be recognized. You would have to rewrite the example and replace all DAQmx functions.
(4,208 Views)
