Labwindows nidaq nidaqmx
hello,
I'm new at nidaq mx. I've created a task in Labwindows.
My Code:
int32 CreateDAQTaskInProject(TaskHandle *taskOut1)
    int32 DAQmxError = DAQmxSuccess;
    TaskHandle taskOut;
    DAQmxErrChk(DAQmxCreateTask("DAQTaskInProject", &taskOut));
    DAQmxErrChk(DAQmxCreateCIPeriodChan(taskOut, "Dev1/ctr1",
        "Periode", 0.000001, 0.1,
        DAQmx_Val_Seconds, DAQmx_Val_Rising,
        DAQmx_Val_LowFreq1Ctr, 0.001,
        4, ""));
    DAQmxErrChk(DAQmxCfgImplicitTiming(taskOut, DAQmx_Val_FiniteSamps, 100000));
    *taskOut1 = taskOut;
Error:
    return DAQmxError;
What are the possibilities to read the samples?
André
(3,055 Views)
A good start point will be
 Help>>Find examples  Hardware Input Output>>DAQmx>>Counter Measurements>>Period or Pulse Width >>DigPeriods-Buff-Cont-HighFreq2Ctr.prj
"A VI inside a Class is worth hundreds in the bush"
യവന്‍ പുലിയാണു കേട്ടാ!!!
(3,048 Views)
