Language issues
Hi all!
I have downloaded and installed the NIDAQ 8.3 device driver, but can't seem to get it installed in English. It installs in German and then I have a German version of the Measurement and Automation Explorer. How do I install the software (or which version should I download) that I have everything in English?
Thanks for any help
Charel Marais
(2,923 Views)
While there are different LabVIEW versions for english and german, there is only one language version for drivers (including the Measurement and Automation Explorer), so the language used by MAX depends on the language of the operationg system. You can change this by following the linked knowledge base:
http://digital.ni.com/public.nsf/websearch/9893C1767C93D20E86256F49001CDA92?OpenDocument
(2,904 Views)
