I have an older data acquisition system that has performed flawlessly for 5+ years. Now I am experiencing a DC offset voltage of 0.1394 volts on the NI 6011E on each channel of the system (this is on the +- 10 volt scale). If I switch to a +- 1 volt scale, the DC offset voltage is 0.01394 volts. I call this an offset voltage because this is the voltage I read when I short the two leads connected to a floating channel together.
This system has never been calibrated. Do I need to calibrate the board or replace it?
I have a large number of new systems using Labview 8 with newer hardware. This system is a legacy system and is not used that frequently. If I upgrade one component -- I will need to replace the entire system (computer, operating system, data acquisition, MAX, Labview, etc.). So, I am trying to get it corrected without replacing anything.
I could do something very kludgy like putting the offset voltage into Labview as a constant and then subtracting this value from every measured result.
